New maintenance releases: Nextcloud Hub 25 Autumn & 26 Winter
Important notice (27.03.26, 3 PM CET)
The releases 32.0.7 and 33.0.1 have been stopped for a regression in the sharing sidebar.
Please update to a new version to keep your data safe!
If you are using Nextcloud Hub 25 Autumn or Nextcloud Hub 26 Winter, we strongly recommend you to update to version 32.0.8 and 33.0.2 respectively. Maintenance updates include important bug fixes, stability and security upgrades. It is a quick and safe process, as always!
About the updates
Earlier, we had to stop the updates to versions 32.0.7 and 33.0.1. due to a regression in the sharing sidebar. Below you can find the information on the follow-up versions.
The maintenance updates include a number of important bug fixes and improvements in all supported Nextcloud Hub versions. You can find the full changelog on our website.
Found an issue? Please report any issues you find in our GitHub repositories.
Updates are available for:
  • Nextcloud Hub 25 Autumn (version 32.0.8)
  • Nextcloud Hub 26 Winter (version 33.0.2)
Nextcloud Hub 26 Winter for Nextcoud Enterprise deployments
We are making Nextcloud Hub 26 winter available to the Nextcloud Enterprise customers. It begins with 30% roll-out, and will become gradually available on all instances over the next weeks.
Nextcloud Hub 26 Winter: Reclaim your digital autonomy
What’s new in Nextcloud Hub 26 Winter:
  • Growing sovereignty: new federation features, improved data export and import
  • Nextcloud Talk: live translations, pinned messages, scheduling
  • Office document comparison
  • Whiteboard: comments, reactions, timers
  • Nextcloud Assistant performance upgrade and AI labeling
  • Powerful E2EE in the web interface
  • Speed-up with ADA engine … and many more improvements in all apps!
Regain your digital autonomy with Nextcloud Hub 26 Winter
Our latest release of Nextcloud Hub 26 Winter is here! Discover the latest Nextcloud features.
Always keep your server up to date!
Nextcloud’s minor releases primarily focus on addressing security vulnerabilities and functionality bugs, avoiding major system overhauls that could jeopardize user data. Keeping your server up to date is vital, and our approach to testing and validation ensures that upgrading to minor releases is generally smooth and reliable.
For mission-critical Nextcloud systems in enterprise settings, consider switching to Nextcloud Enterprise. The tier provides you with ultimate deployment confidence: direct access to the Nextcloud engineering team, full assistance throughout deployment and integration, and peace of mind for system administrators. If you’re responsible for maintaining Nextcloud in your setting, this option may be the ideal solution for you.
